shimming a lower unit?
PowerAddict
Okay, so my volvo outdrive..the one I ask about every other day! :D
its a 290. If i were to put a 280 lower unit on the upper, would I need to shim it?
If so...what in the world is that?
jerryjerry05
Re: shimming a lower unit?
Most Volvos I have worked on have shims between the upper case and the lower leg.The bearings in the upper need clearance so the bearings don't rub on the lower case.
I don't know how it's done,sorry.J
PowerAddict
well if i change lowers, but its still a 290 does it need shimming?
Don S
Absolutely.
When you put a new lower on, you MUST Use the bearing race on the vertical shaft from the NEW lower unit, and it needs to be reshimed.
PowerAddict
well...in the outdrive manual does it have the procedure?
Matt
