turkeycreektrout
Thread starter- Joined
- Apr 19, 2008
- 16
i was at the lake today. my 98 johnson 115 v4 faststrike-when you start it(in neutral), there is a beep and a system check gauge that goes through 1 red light for each of the 4 warnings.
so i pulled up on a spot and when i moved the throttle back to neutral before turning it off, there was this "click" in the motor and then the system check came on(see above). this isnt supposed to happen until you start it. i moved it into gear then back to neutral(running) and the motor "clicked" again and again the system check did its thing. i turned the motor off and back on and the usual system check came on, i put it in gear and back to neutral and it didnt do it this time(normal operation)
anybody have ideas?
thanks
anybody have ideas?
thanks
