Re: 79 Merc 200
Re: 79 Merc 200
If a 68, should be 2296267 - 2550064, so a 7 digit number stamped on the block.
I think this vintage stamped the number on top of the block near rear where the water tattle tell hose exits the powerhead.
Also later stamped on the block on a boss starboard side near rear near top. And later stamped on the port side near front near top where cranks halfs split. I have also seen blocks very late or must be a replacement powerhead with no stamping. Should be an aluminum nametag on the tilt tube between the clamp handles, sounds like it is missing.
Good luck, hope this helps.
