I hydrolocked my engine a couple of times. What's the chance of a bent con rod?
rs2k
While trying to figure out if the engine had a blown head gasket (which it did), a cracked block, or a bad manifold, I hydro locked the engine a couple of times. Each time it happened I pulled the plugs and spun the water out. I didn't try to crank it over when the starter would start to stall.
TilliamWe
Banned
Re: I hydrolocked my engine a couple of times. What's the chance of a bent con rod?
You sure about your exhaust manifolds?
Usually a starter motor will not bend a connecting rod. Of course there is a chance, it's just a smaller chance.
bigred69
Yes you can bend a rod or break the crank from hydro locking your motor. Depending on how much water is coming into the cylinder and how fast the starter is spinning. IT CAN HAPPEN! I have seen it many times.
wca_tim
I would reeeaaalllyyy check those manifolds based on what you're posting....
note that water intrusion is an easy way to blow a head gasket, eh?
How old are the manigolds? have you pressure tested them?
rs2k
Here is what I know:
Engine not on hose:
Engine runs fine.
Engine and both manifolds hooked up to hose:
Engine runs fine until cylinders 2,4,6,8 start to flood.
(When left hooked up to hose like this and engine off the cylinders flood.)
Everything but port manifold hooked up
Engine runs fine.
(When left hooked up to hose like this and engine off the cylinders DO NOT flood)
I pulled the riser off the port manifold and it looks like the gasket might have failed. The gasket is so old it's hard to tell though.
danond
A cooling system pressure test would be good, too.
Don S
Usually, the gasket doesn't fail, what happens is the gasket surface of the manifold and/or riser corrodes away.
attachment.php
rs2k
Thanks, that looks like the problem. The surface was corroded. I better replace all 4 manifold gaskets then. I also need new rubber exhaust tubing. Where can I get that tubing and what's the easiest way to install it when the exhaust manifold is not apart?
I have a feeling the previous owner used RV and marine plumbing antifreeze to winterize the motors.
Don S
If the surfaces of the manifolds and risers are bad, you need new manifolds and risers. Not just gaskets.
The wrong decision can cost you an engine along with the manifolds and risers.
rs2k
Can they be resurfaced?
Don S
Clean the gaskets off and post pictures of the gasket surfaces of both the manifold and riser where they go together.
Note: A blurry picture won't help.
rs2k
The corrosion is not that bad. It is just pitted at the meeting surface. It almost like the gasket was not pressed enough. The part that is still good is still shiny.
rs2k
Here are some photos. I hope they are not too blurry.
rs2k
The gasket fell apart upon removal. I did not scrape all the remnants off the engine half of the manifold because I didn't want FOD in the cylinders.
TilliamWe
Banned
Engine not on hose:
Engine runs fine.
Engine runs fine.
Okay, all your tests and condition of your manifolds point to the manifolds being bad. I can't tell from your photos, cause they are too blurry, but I am guessing that you have junk exhaust manifolds and risers.
rs2k
Hmm, where's a good place to get 4 OMC exhaust manifolds and risers?
danond
eBay's always good, but did you mention what kind of engine/drive combo you have?
rs2k
Twin OMC stringer 800 series with Chevy 350s putting out 260 HP each.
Looks like about $1000 - $1200 to replace all the manifolds.
