centuryexpress
- May 22, 2009
- 5
Ok, I did a bunch of searching, but I am still having an issue, I think. Last year when i got outmy boat, on the muffs, the overheat buzzer came on. Not wanting to deal with it, I just refogged the motor and put her back.
So I get her out this year, put on the muffs, and start her up,, The temp gauge with muffs gets up to about 180-90, and the starbord top head gets hot,, you can keep hand on for a while, but not indefinately, buzzer did not go off. Port head stays very cool.
I went ahead and changed the thermostats, ,no change. The impeller is fine, good pressure. When I take off the hose coming from that head to stat housing, I have good water flow, and head cools right off. Soo, impeller ok, new stats, and head still getting what seems to be too hot. Is this a function of running off the muffs (does not make sense, with a pressurized supply of cold water going in)... If the deflectors in head were not in place, then it would not cool off with hose off either, correct?? Wondering if I should just pull the stat on that side, would it run ok or be too cold?,,,
'Any help appreciated.
Oh, the vent hole in the housing is clear, just for info. freshwater boat.
