Steelwolve
Thread starter- Joined
- May 19, 2009
- 3
Hello all Im new to this site and had a couple of ?'s, if anyone had an opinion it would be much appreciated.
As the title suggests I have an oil leak in my 1962 5.5 hp Johnson. After reading the FAQ post on this subject im still unsure. The leak is coming out of the weap holes (water drain holes also maybe?) in the lower unit. I have changed the gear lube 3 times since ive had the motor, (about 3 months) and find it looking good with no signs of water, so Im pretty sure that it isnt gear lube oil leaking out, as the article stated id probally see water inside the gear case, more than what comes out. So im leaning towards the unburned oil as the cause, but the article says it should be black and sooty unless coming out of winter, right..?? Well my leak looks more like dirty white lithium grease. Ill attach some photos for reference. Its gotten worse since my last few uses. Also I took apart the gear case and the o ring seal and case seal were in good shape so I cleaned them up and added some silicone before reinstalling, will that work??I know I shoulda probally gotten new seals but dont have the time to wait on shipping. Whatta think???
