I found out today why my boat has been running so badly... There is a threaded bracket, that is attached to this bar that moves when the throttle is pulled. From the looks of it, this bracket should have a screw threaded through it which possibly controls timing?
What is this piece called and where the heck can I get a new one?
Thank you in advance.
Edit: there is currently a zip tie attached to the screw that turns a disk under the flywheel... i have no intentions of running it this way. FYI,
