Deco_Prokat
Thread starter- Joined
- May 13, 2009
- 5
I'm the proud new owner of a 2001 28' Prokat w/ twin 2001 Suzuki 225?s w/ EFI
Over the past few days I've had some issues with one of the motors. I've detailed as much as I can remember right now and was hoping someone here might be able to point me in the right direction.
Rt. Motor turns up fine, runs 5500rpm @ WOT
Lt. Motor ran fine @ 5500rpm initially @ WOT, and both motors settle between 42-4300rpm @ cruising speed.
After roughly 30 minutes of cruising, the Lt. motor dropped to 3000rpm and wouldn?t go above 3K even @ WOT.
After about 5 minutes of running, the rpm?s started to creep back up, and both motors went to 5500rpm again when testing WOT.
After a brief rest, rt. Motor continued running fine, and left motor was rough again @ 3000?ish rpm.
I left it full throttle and the rpms jumped after a minute or so to 3500, then 3800, then rose quickly back to 5500 @ wot.
Since then, I?ve replaced the spark plugs and primer bulbs b/c the left bulb looked like it might be leaking / dry rotted.
Today, when I pumped the primer bulb until it was full/firm, it began dumping fuel out of the air intake.
Any ideas? Any suggestions for a Suzuki OB newbie? :redface:
Thanks,
Deco_Prokat
Thanks,
Deco_Prokat
