I Blew It. (It's okay to laugh.) Now with video link.
Tryinboatin
Good Day All:
I'm new to boating and have found a tremendous resource here with all your expertise and am grateful to each who volunteers their time. But I found it a little too late.
I bought a $500 roadside special: 1975 Glastron tri-hull with an incredibly-clean 50 horsepower Johnson (50ESL75B). It was claimed a one-owner boat that hadn't been run for five years. I let it sit with Mystery Oil overnight, then got the flywheel moving with hands, then a wrench, and finally it would spin freely with the starter (plugs out). Every so often it would come to a harsh stop, but I didn't pay much attention to that. I put the plugs in and it ran for three seconds (wife was videotaping the big moment) and blew a hole in the side of the powerhead.
Not sure why it happened, but have found a wrist pin with no needle bearings, a cracked cylinder wall and a piston with needle bearings embedded perpendicular to the ring lands. I've since found a similar powerhead on a donor engine ($100), that turns over easily with the plugs in and will attempt to swap the parts over. And to think; a week ago, I didn't know what a powerhead was.
I'm a little reluctant to ask because I'm disappointed in myself, but does anyone have any advice or suggestion to what I did wrong? Thanks in advance.
IVAZ
Master Chief Petty Officer
Re: I Blew It. (It's okay to laugh.)
Sorry to hear about your engine.
I dont really know why your engine threw a rod (poor lubrication?).
But uh... you say you have a video? You should post it.
Tryinboatin
Thanks. Should I include the part where I say, 'Well, kids, did you like having a boat?' I'm not giving up that easily though.
TWFisher
Sorry to hear it!
I know for me bringing an old boat to life has been an expensive emotional roller coaster, but with pay back...I'm runnin strong now! Some days you make progress and some days take steps backward. Keep working at it, but get your self educated on the subject at hand. Get a manual, a good mechanic and search this forum for Q&A. Good luck.
jonesg
What you did wrong?
well the sign was there, engine had a harsh stop, something was locking it up but you ignored that and fired it up. I'd say the rod was gone already.
cbavier
I assume you ran it on muffs
kenmyfam
Sorry to hear that.
From the description it sounds like there was something wrong internally to begin with. Especially when you mention the harsh stop.
Well you will get all the help, assistance and advice you need out here for your repairs. Good Luck and welcome to iboats
Tryinboatin
Yes, muffs were on.
I guessed that the harsh stop was a combination of a relatively-weak battery and weak return spring on the starter. I noticed that the spark plugs were just a little more than hand-tight, but figured that was because they're threaded into aluminum.
Thanks for the consideration guys.
Karl
ebry710
Ensign
Time for craiglist/ebay for old or iboats for new ones. If your new to boating, old outboards are not the way to go without a good mechanic. Firing up an unused engine is not for the faint heart ed.
freddyray21
the harsh stop was a broken rod or wrist pin already.
gonefishie
I (WE) demand mentioned video before further helps. :D
Tryinboatin
As requested, video is made, but I'm not sure how to post it. It is an .mpg file.
The video contains an "exploded view" of the engine.
Thanks to all for their input and suggestion.
Hanr3
Curious as to why you want to take the power head off one engine and put it on another? Why don't you use the engine with the good powerhead? Save the one you blew up for parts?
amd yees, post the video.
Tryinboatin
I shoulda mentioned; I'm using the powerhead off an engine that has a junk lower unit. Thanks for asking.
gonefishie
Sign up for an account with photobucket.com (you will need it since you're going to post pictures to accompany your question/project). After sign up, upload your vid. to photobucket. Read the sticky on how to post pic/vid on this forum FAQ section and follow the simple steps.
Nandy
I guess we are not going to see that video. :-(
hazwild
Come on where the video
kenmyfam
We would really like to see the video !!!!
Sikiguya
Video! Video! Video!...should even post it on Youtube!:cool:
