pkrainert
Thread starter- Joined
- Jul 27, 2008
- 196
I have a 6.75 hp lawn mower that will only run if i put gas in the carb directly or in the cylinder. I took the carb apart and cleaned everything out. I didnt have a rebuild kit but tehre isnt much to the carb there is no diaphram it is gravity feed... After cleaning it out and putting it back on I had the same issue. So I took it apart again to try and re clean it and make sure everything was put together right... in doing this I broke the primer base... so now when i pump the bulb it does no good because where the gas used to be sprayed is a big hole.... My question is do I need to replace that base?? or will it run ok if I just rebuild the carb?
