JohnMcL2000
Thread starter- Joined
- Apr 26, 2009
- 8
This is my second post. Got some good suggestions the first time, but still at a loss as to why this engine will only run when fuel is sprayed into the carb.
New float, checked with Johnson gauge: level and drop OK,
cleaned all parts of the carb,
needle valve looks OK, no dents or dings,
jets [high and low speed] all clear of gunk,
valve turned in to seat and backed out 2 turns,
new 'boss' gasket and other gaskets installed,
with hose to carb off, fuel flows when cranked,
fuel drains from bowl when bulb is squeezed [drain screw removed],
roller hits cam at mark, opens throttle a tad,
good spark at plugs,
points set to .020, plugs to .030
new thermostat and good water flow,
If I spray fuel, it runs fine. Guess I'll just get a 6 gallon spray bottle and exercise my 'shooting' finger...:~}
Next step appears to be repair shop...or boat anchor...j/k
