toolsinbox
- Apr 22, 2009
- 187
I have ordered new guages for my 89 21 ft scarab. 454 ls6 engine, alpha outdrive. Currently the tach works, the fuel guage worksbut they are all different brand guages and look baaaaaad. I checked the fuse block and noticed one of the fuse holder was broken. No biggie as it was not being used but I want to replace the entire fuse block for a modern one. I want to rewire the entire helm and install second battery to run accessaries like sterio lights etc. I have no problem doing switch and second battery as I have done it before.
My question is once I get the battery switch and second battery hooked up what and how many direct power wires do I need to bring to the helm and what guage wire? Same question for the groung. Obviously I need to bring a power wire to the fuse block. What guage wire should that be? What components should be run through the fuse block and what should not be. How do I know what size fuses to run in each item. For example, I have an msd ignition that I am sorting out and have to correctly wire the key switch to shut off the engine. What size fuse do I use there?
Secondly the power trim works great I have a up down switch mounted on dash along with a up down switch that is on a wire coil that can be hand held. Dose the trim run through the fuse pannel or is it direct wired.
As you can tell I am a bit over my head with all this but I am determend to make this all work and look great. The boat runs like a dream I guess the previous owner didnt get to the wiring before passing away.
Any help here would be great
