I replaced the solenoid & it seemed to correct the problem for a while but now I have to jump start it at the solenoid. It starts & runs fine after that but still won't start by using the ignition key. Also the tilt & trim switch on the throttle handle will not raise the engine. It will lower the engine and the tilt & trim switch located on the side of the engine works in both directions. Could my problem possibly a bad ignition switch?
