Good Evening,
I have a 85hp Johnson on a recently acquired fishing boat (1977 77EL). I R&R the water pump assembly...impeller, housing, gaskets, seals using a Clymer manual for the procedure. With the lower unit removed, I verified that the water tubes were clear. The impeller that came out was in fairly good shape, but had taken a set. My question is (the clymer doesn't address this) where does the water exit the engine. Is there a "pee" hole? Their are two holes just below the hood that spit water and I was able to see the water hoses on the engine for those exit points. But, their has to be more water than that circulatating. Does it also go out with exhaust?
Thanks in advance for the help with the rookie boater.
