lower end gear oil
allenprimo913
what kind of oil is it? and wgere to buy it plus how to drain?
theres i 2 plugs, one is vent on top and one is fill on the bottom?
how to drain the oil if the fill is on the bottom and the vent is on top.
put the motor upside down?
dumb question but i need help. how mucxh oil or fluid?
thnks
:D
:p
HAV2FISH
Re: lower end gear oil
You can get the oil from your local dealer and also get the seals for the vent & fill screws.
You do drain and fill from the bottom. This helps keep air out of the oil. just place the end of the tube in the fill hole and squeeze the oil in. when it comes out the top its full. Just let it sit for a 1/2 hr. to let air bubbles to work there way out. Then top it off. Your done, Its that easy.
allenprimo913
thanks for the response , i havent done it before.
my problem is now have to find a outboard/ parts around the area. i always order parts here from iboats but i dont know what exactly kind or type of oil to put in there
sailingwest
Hi , Make sure that it is the drain plug that you are opening on your lower unit if it is 70hp and up ,the drain plug is on the underside of the gear torpedo just in front of skeg ,There is a screw on the side below the fill /vent holes that can easily be mistaken for the drain ,removing this screw will turn a simple job into a nightmare, as previous reply states the reason for filling from the bottom is to purge air. Jim B
HAV2FISH
Walmart also has lower unit oil
mrwiggles2
The vent and drain plugs are the same, dime sized flat head screws. The one you don't want to remove is a smaller eraser head sized screw that is a rounded slot screw. Remove the two that look the same, if that is easier.
allenprimo913
ok thnks
so to make my confussion clear
FILL - is on the bottom where to fill the oil
VENT / DRAIN - has to be taken out while filling it with oil
so you can do this while the motor is in the standing position, no reason to put it upside down or tili it.
am i clear on this
if it is THANKS A LOT TO ALL THE HELP.
:p :p
allenprimo913
thank you, im off to walmart in a minute
and i will post back
thnsk again
