So I just bought a 1990 Bayliner with a 90 Force on the back of it. This is My first boat and I am completely clueless about it all. Was all excited to get going and have some fun, but alas, she isnt running right.
First off, it takes a very long time to get it started. I use choke on ignition, prime bulb, pull out lever to disengage gears.. I try everything.. When it finally does start up, it has whats best described as a sneeze every so often..
The second major issue is that when I get it started, and it is idling, the stalls out the second i put it into gear.
I have changed the plugs and it changes nothing.
From browsing these forums with cases that may be similar, I have seen things like adjust the idle, change the Switch box Assembly etc, but I am not sure these cases were the exact as mine, so I was hoping to get a little help of my own.
At the moment it is at the marina, where the mechanic is going to take a look at it.. Funny thing is that the mechanic has taken the boat out twice when he did the spring startup on it, and said it worked fine besides the "sneeze". Yet when I go there, it just won't go into gear without stalling out.
Any help would be appreciated.. Thanks so much!
