atv-doctor
- May 3, 2009
- 7
I've been reading posts on here for awhile and have not seen any specific posts on this topic so if you can help it would be great
I recently bought a 12 foot jonboat with an included 7.5 Sea King outboard so i was working my way through start up i began by digging out an old mouse nest and checking general condition all seems fine.
next i moved on to spark pulled plug and lightly pulled cord motor turns over easily so i checked for spark by installing plug and pulling cord no spark so i figured points might be bad so i pulled flywheel and then thats when my whole method changed it doesn't have points thats when i noticed on the cover it says solid state ignition. the ignition seems very simple stop button,coil,plug wire,plug that is the entire system so i assume the coil is bad and needs replaced.
Now for the questions, I tried disconnecting the stop button still no spark, Am i correct in assuming the coil needs replaced?
What is correct plug? it has an autolite in it now.
Is 40:1 the proper mix ratio air cooled so use quality chainsaw oil?
What is the procedure for changing impellor,if i can find one?
Need info on carb and fuel pump cleaning?
Now for the important stuff-
1978 Sea King 7.5 (Clinton)
model# K7535106 C
serial# 1540890
type# XTV 52307 C (X might be a K tag is damaged a little)
model# K7535106 C
serial# 1540890
