White Vinyl Seats No Longer- Any Sugggestions?
Bellono
Does anyone have suggestions on how to recondition White Vinyl seats so they appear white once again, without ruining the integrity of the seats? I have a one year old boat with White Vinyl seats, however, there is ground in dirt in the seams and in the texture of the seats, not to mention a yellowing hue about them.
I am very particular about my seats being clean AND white. I am not giving up hope that they can be that way again.
THANKS
Tim Frank
Re: White Vinyl Seats No Longer- Any Sugggestions?
Third door down the hall is the i-Boats store. They will no doubt have a host of vinyl cleaning products.
If they stock one called Starbrite Vinyl cleaner and polish, it really works well.
Use a toothbrush (a retired one) for seams and nooks/crannies.
Bellono
Thanks Much. Starbrite and WestMarine vinyl cleaner has been working along with the toothbrush. Maybe it will take a few cleanings over the next couple of weeks. I can not get the yellowish-gray tone out though. I do not want to go the bleach route.
capt sam
Master Chief Petty Officer
worse case scenerio you can repaint them with vinyl spray paint, works pretty good.
fishrdan
I used some clothes spot remover my wife had in the laundry room (Shacklee Basic-I, Shout, something like that...) on my white vinyl seats and they came out perfect. I poured some of the spot remover in a bucket with just a touch of water, wiped it on the vinyl with a rag, scrubbed it a bit with a plastic scrub brush and then rinsed it odd really good. A few area's I had to clean twice as it came out streaky,,, I didn't scrub it enough.
I actually got the idea when I was using the stuff diluted to clean the interior and accidentally dropped some of the straight spot remover on the dingy white vinyl :eek:,,, Hey now, that came out perfectly clean, almost like I bleached it ;)
I'd test an inconspicuous area first (not the middle of the seat like I did) as the vinyl in my boat was 3-4 years old and not in the best of condition to start with.
cribber
Re: White Vinyl Seats No Longer- Any Suggestions?
Mr Clean Magic Erasers!! They have a slight abrasiveness that removes surface stains. Just keep the pressure light as needed.
kenmyfam
Did you "choose" white or did you have no option ??
I had no option and suffer the extra work each season !!!
Wickerbill
I used a Mr. Clean magic eraser and some 409...worked like a charm.
