PNW Driver
Thread starter- Joined
- Apr 29, 2009
- 55
I bought a 1969 Reinell 19' with a 4 cyl gm motor from a guy at work for 200 bucks. It belonged to a professional mechanic before him that also is a coworker. The mechanic rebuilt everything in 1996 but the last guy ran it and parked it. I am not sure which model outdrive it has. The engine wouldn't turn over and we determined the cylinders were free. Then we popped the top off the outdrive to take a look and found zero lube and rusted gears. The bearing on the top of the vertical shaft was frozen. We added lube and cranked the motor(no plugs) with the top off and everything rotated fine with the top off. Obviously, the top bearing has to go. I am thinking the larger bearings holding the gears as well. In addtion, there seems to be corrosion damage and I wonder if I will need a new outdrive all together. Any help would be very much appreciated as this is my first boat and I am learning as I go along
