Can someone point me to a thread where instructions are given? 1956 10 Hp Johnson...thx
S STEVE IN SOCAL Seaman Apprentice Thread starter Joined Apr 12, 2009 Messages 42 Apr 27, 2009 #1 Can someone point me to a thread where instructions are given? 1956 10 Hp Johnson...thx
samo_ott Vice Admiral Joined Jun 18, 2006 Messages 5,125 Apr 27, 2009 #2 Re: replacing impeller '56 10 HP If you search you'll find it. But it's pretty easy. Remove the shifter cover and disengage the shifter, then drop the LU by undoing the 4 bolts. You will see the water pump. should be 4 screws holing it on. remove it and replace the impeller.
S STEVE IN SOCAL Seaman Apprentice Thread starter Joined Apr 12, 2009 Messages 42 Apr 28, 2009 #3 Re: replacing impeller '56 10 HP Any gaskets involved?
jasper60103 Commander Joined Sep 18, 2008 Messages 2,055 Apr 28, 2009 #4 Re: replacing impeller '56 10 HP You should replace the vent/fill washers when refilling the lube.
samo_ott Vice Admiral Joined Jun 18, 2006 Messages 5,125 Apr 28, 2009 #5 Re: replacing impeller '56 10 HP No gaskets. Unless you're doing seals also.
