Mark42
- Oct 8, 2003
- 9,334
Re: 1986 Force '85
Remove the carbs and clean them. They are very simple and easy to remove and reinstall. Took me less than 15 minutes to get them off the first time I did it.
It pays to stuff a couple of towels around the base of the engine shroud in case you drop a screw or nut down there. Its a pain to get them out.
Should also get some fresh fuel line and replace everything from the fuel pump to the top carb. Its probably hard and brittle anyway.
The choke solinoid plunger just pulls out. Seems rather odd, but that is the way it is.
Also, a spray bottle of gas/oil mix should be used when testing the motors to spray in the carbs rather than starting fluid. Thats because starting fluid can cause back-fire through the reed valves damaging them, and it also provides NO lubrication that the 2 cycle motor needs.
