rsimmons42
- Aug 25, 2008
- 194
I just used J. Reeves timing method. Seemed easy enough. The question I have is now that it is se at 4 deg. below spec. The timing Base has a total movement of about a inch. Does this seem right.
I went out on the water today to test the timing with the other method that I had used, didn't seem right, so I came back in. The engine had a vibration that I could feel throughout the boat. The Service manual for my engine says .040 on the sparkplug gap, changed them before I went out from .030. I have since changed them back.
When I did the Reeves method, it showed the timing to be to much advanced by 6 deg.
When I adjusted using his method, I just about ran out of screw.
Please tell me if the timer base should be moving more.
What is causing the vibration.
I have a 1977 70 hp Johnson, all new ignition system, good spark, excellent compression, and the prop is good. What is happening.
