Trim switch on lever
Roller
How do I get the switch out of the handle to replace I was having problems leg wouldnt go up and down and i have traced problem to switch but i dont know how to get it out its a mercury handle but i dont know if that makes any difference.
Thanks for any help or advice!!
Bt Doctur
Re: Trim switch on lever
If the switch is at the very top of the handel ,remove the round cover and the switch lift out
If it`s in the side of the handel , removing the screws ,the outer cover, allows access.
But without a pic,model number ,etc. it`s harder to give the correct answer
180shabah
Which Mercury "handle" is it. They have made several over the last 5-6 decades.
liquidlew
If it's on the upper part of the throttle handle like mine (1989 Merc) there is 2 screws you remove and the plate comes off exposing the switch. I just checked mine cuz my drive is not working presently (bad solenoid), all my switches are good. I hooked up an ohm meter to the harness plug at the solenoids and I get voltage when I engage the switches. If you do have the same switch setup and have to replace it, let us know if you can get the exact same replacement! I have a feeling I will need one someday!;)
Roller
Thanks for help guys I got it apart and found a broken wire in the handle so I repared and it all works great so problem solved for now!
