DeCarbing Was A Bad Thing???
Boss Hawg
As i said in a earlier thread i checked the compression on my 1987 70hsp Johnson & the 3 clyinders varied from 135 - 150 -
I just checked again after a fairly goog decarb job & all 3 dropped compression but now all 3 are at almost exactly 120 :confused:
Is this good or bad???
iwombat
Re: DeCarbing Was A Bad Thing???
Could very well be you removed some big carbon deposits from the top of the pistons, or the inside of the heads and lowered the compression a bit. Yep, that's a good thing.
Boss Hawg
Whew-- I was sure hoping so :D
Thank you for easing my mind quickly!!!!
bob johnson
I just popped the heads off my 1988 70 ...and whuile I have had a previous problem which left me with shrapnel embedded in the head and the top of the piston..there was only a little carbon on the piston tops in the two cylinders with out the issue... and almost none on the piston with the shrapnel...
all three chambers of the head were as clean as a whistle...ZERO carb....
zilch...
is this common?
where else does the carbon build up , that needs the benefit of a decarb???
down the intake at all??
down the exhaust?
THE CARBONIZATION is only the result of burnt oil-gas???
thanks
bob
JB
Bob, you need to start a new thread with a new question. Hijacking is bad manners.
bob johnson
I was going to later on today...but when i read about the carbon that guys say builds up on the piston and cylinder..i thought it was a perfect time to post a cylinder with no carbon.... and ask the question.
my thinking was guys who know about that stuff and who were already in on the thread could easily reply.
I'll try to behave better from now on....
I still have a lot of work ahead of me on the 70HP
bob
Boss Hawg
Thanks JB :cool:
Bob, no harm, we all want to get our stuff going right :D
bob johnson
Thanks JB :cool:
so you wanna trade motors right now straight up????( there is room to twist my arm tomorrow) ha ha
ps all the paintable parts are all redone and ready to bolt on!!! and you get a whole year newer motor ha ha
bob
Boss Hawg
bob
Well------Yours is a whole year newer :rolleyes::D
Best of luck my freind ---
coolguy147
alright... enough boning and sorrys for the other person:cool:
well u rather have a motor 100psi and above and like dead even then haveing a motor have 120 in a cylinder then 150 then 110. ur mainly looking for evenness
tashasdaddy
carbon also builds up around the rings, and can sieze them, decarbing is alike an enema when you are distressed. it gets all the old crud out of the engine. and cleans the exhaust.
Boss Hawg
That puts it into perspective :D
I was concerned on the first since it had dropped & double checked :(
The middle was the same & i was courious :confused:
The last was exactly the same & i thought it was great :D
Took me bout 3 minutes to get to my computer to ask ya'll to be sure :cool:
Thanks again for all the great info i've gathered here!!
