Mercruiser Alpha1 is hard to install
truckermatt
Hello,
i have a 1983 wellcraft elite with a Mercruiser Alpha 1 drive. and when i bought it, the outdrive was removed for storage. But now i want to get it "dewinterized" but i cannot get the outdruve installed.
I put the boat in forward, and line up the shift shat on the outdrive and the bell housing, but i wont slide in all the way, about 1 inch left.
I also rotate the prop counterclockwise in hopes to move the spline to it will catch, but still no go.
Any suggestions.
Zackman
Re: Mercruiser Alpha1 is hard to install
Did you check the alignment?​
JustJason
Check your alignment as Zackman says.... then give it the Mercury Kick :)
kblaksley
Hello,
Any suggestions.
Hello,
Did you lube the gimble bearing o-rings? Sounds to me like your there but o-rings are keeping you from going the rest of the way. (They sit about an inch back)
Wiggle and jiggle or remove, investigate, lube up the o-rings and try try again.
dubs283
First off, check the aligmnment. If everything is okay then buy an outdrive gasket kit. Then download mercruiser manual #6 from the ao sticky thread and follow the steps outlined there.
My guess is the alignment may be out of spec a little but what is happening is the two o-rings on the splined shaft on the drive are hanging up in the gimbal bearing. A little light grease will solve that problem.
Good Luck!
truckermatt
the alignment of what may i ask..... the spindle shaft of the little brass gear selector on the drive?
I gave it the boot, but no go..... I wish the boat was another foot higher in the air, that way i wouldnt be working at a goofy angle.
ziggy
and after the alignment is right, when assembling it. be sure the drive is absolutely even and parallel with the bellhousing. a small twist of the prop to align the coupler splines and it'll just slide right on. when it's perfectly lined up, after the alignment..
truckermatt
no i did not put any grease on the shaft or the o-rings..... i will try that..
truckermatt
i cant got the drive parallel with the bell house because the boat is too low on the trailer i have to angle the bell housing up and then push... otherwise the skag goes into the grass.
kblaksley
Also equally important; "Did you lube your splines"? They will wear out quicker than you can shake a stick.
You should pick up a mercruiser manual. Lots of good toilet material.
kblaksley
I assume you have lowered front jack so back end will be in the air right?
Most run abouts on trailers can be lowered in order to run engine and service drive with oil with drive level.
truckermatt
i will lube the spline too... ( dark out now)... and i do have the orginal mercrusier manual for the motor and i also have a clymers repair manual...... neither of them helped, Yet
also when you say alignment, what part should i loom for.... the little brass shift knob on the outdrive.... i made sure that was good to accept the part on the boat.
truckermatt
darn it.... i never even thought of that..... my trailer tongue is touching the stars its so high...
Thanks for the tip.
meesh
When they are asking you about alignment they are talking about inserting an alignment bar through the gimbal bearing and into the coupler on the back of the engine. A manual will give you the exact procedure or search alignment on this forum and you will find all kinds of info. I also have an alfa and when the alignment is correct it will slide right on. It may be a little stiff when you get to the o rings but I have never had to kick one on. If that's the case it's out of alignment!!!!!!!!!
coastalcruiser
That's good advice, the bar has to slide in real easy, the way you use one is lightly grease the end that goes into the engine coupler.
Take it out and look to see that the lines the coupler makes are even all the way around.
I my case installing a new motor I found short marks on top of the bar, lowered the engine bit by bit until the bar slid in.
Cheers,
Rob
Fishermark
Not to beat a dead horse here... but you really do need to check the alignment. It will probably be possible for you to physically get the outdrive back on without doing the alignment - especially after you lower the trailer tongue. ;)
But if your alignment is off, then you will destroy your coupler in a short amount of time. Then you will have to be towed in and spend a bunch of money repairing things. Go ahead and spring for an alignment tool and read up on how to align the engine. It is a skill well worth learning!
searay3
Make sure you have the prop locked in forward gear also or you are hitting the shift dog trying to put it on...Move the dog straight forward as you lock the prop and the hold it with a bungee while assembling....
truckermatt
Thanks for the tip.... But the previous owner just removed the outdrive for storage reasons. so i would assume the engine is in alignment.
Ayuh,.... It's 26 Years Old,.... I'd Assume Nothing....
