Wanted to get your thoughts on a problem with the old barge before I tear into it. The boat/motor has had very little maintenance in that past few years before it was given to me but with a fresh tank fuel it started and ran well a few weeks ago. No problems at all. However, the other day it started to lose power and drop to about 2000 RPM no matter the throttle position. it cleared up once and I got power back fo a while but it returned to the same problem shortly afterward. No stalling otherwise and it idled fine at the dock.
I'm thinking this is a fuel starvation/restriction issue. Partially clogged fuel filter??? Clogged pick-up tube??? Didn't think to check the fuel bulb at the time as I was beginning to worry about weather but due to age I may replace it anyway.
