I cut out all the wiring to redo it, but now am having trouble understanding what I was dealing with. The trim will go down, but not up. I traced some wires around. From the trim motor's electrical panel inside the motor, I have 5 wires coming out: red w/ white stripe, green w/ white stripe, blue w/ white stripe, white w/ brown stripe, & black w/ brown stripe. I connected the white to the sender terminal on the trim gauge/meter because it appeared to have previously been connected there. The red, green, & blue wires all go to the throttle handle. I presume the red to be +, the green to be "trim up", and blue to be "trim down".
1) Does it sound like these 4 wires are connected properly?
2) Where should I connect the white, brown wire?
