Expidia
Thread starter- Joined
- Aug 26, 2006
- 2,374
So the C/S at Teleflex steering systems suggested to me that once a year I should detach the end of the steering cable where it connects to the O/B and clean the old grease out of the tube. Then apply a good quality lithium grease and reassemble.
So how do I get the grease out of the tube once the cable is out. If I squirt solvent thru it some might remain and break down the new grease.
If I run a rag thru it fibers might get in there and impede the cable action.
It has a grease fitting in the middle of the tube but he said to clean it out anyway. I wanted to replace that brown messy grease anyway with lithium cause when you add grease it continually oozes out of both ends from use and gets on my trailable cover.
The grease tubes I have now which I used last year on other fittings and my hubs is the Mercury Quicksilver stuff for my grease gun and it's black and quite messy stuff.
So anyone know the best way to clean the tube out and maybe a brand of grease. Does Walmart carry lithium marine grease. I know West Marine will charge double.
