How to remove bottom pin in tilt and trim unit
benney
Hello everyone. Nice looking site.
I'm need to remove my tilt and trim assembly to replace the reservoir and noticed the lower pin does not push out either side of the mounting brackets.
Am I to presume that I need to lift the motor and separated the mounts to release the bottom pin.
This is what I have.
2001 70hp Evinrude outboard
Manf. Date 10/2000
Mod. E70PL4SI
Ser. 16012913
Pictures below to help.
benney
Re: How to remove bottom pin in tilt and trim unit
Just to add this.
In the bottom picture, that painted round section where the pin is. It is a part of the casting and the same on the other side.
benney
Just to let you know that the job is done.
You have to suspend the motor and release the starboard side of the mounts.
Took about 2hrs to do.
Thanks for the advice.
jonesg
We couldn't have done it without you.!
Is that a freshwater engine?
Theres a suspicious lack of corrosion on it.:cool:
benney
LOL
Yes it is a fresh water unit.
Lake Ontario and some surrounding small ones.
George perez
I need to remove the trim and tilt unit , is a 1999 200hp evenrude and there is no way I can remove the pins so I can remove the unit so I can replace it, if someone can help me I will appreciate it
boobie
It's not nice to hi-jack a thread. Please read the rules at to top of the forum and start a new one !! Thank You.
