plasticman
Thread starter- Joined
- Sep 29, 2008
- 2
Ok, just got my power head back from complete rebuild, looked like I dropped a needle bearing from connecting rod which made the piston look like a porcupine, installed the power head, then dropped the gearcase, opened up water pump AHHA, reason for powerhead failure, only one impeller left and the others floating in the housing, replaced the entire pump. Now, question, when I assemled the water pump housing back on I turned the input shaft clockwise looking down at the top of the gearcase to have the impeller vanes in the correct direction, is this right, please tell me it is. I also did top input shaft seal and am doing the bottom tonight, have bearing unit out but need to have the seals pressed in. Also, when we start this baby up for the first time what should I look for for water flow, should it come out of the rubber bushing at the back side of the engine, is there a thermostat, how much flow should I see. Thanks guys!
