another cd 17 ???
onyx
i just opened the drain screw at the bottom and water came out, I'm guessing this is not right. The top screw that says oil fill line has water coming out too but the lube is pure black . Bad seals ?? which one(s) ??? Sure wish i would have found this site BEFORE I went shopping !!!! Thanks in advance!!! Matt
F_R
Re: another cd 17 ???
Bad seals? Absolutely!! Which one? Can't tell you. Only an inspection will tell. Has it done damage by running with being full of water? Very possible.
I suggest a complete tear-down of the lower unit and replace all the seals. Don't ignore the shift rod seal.
onyx
Any idea of cost to do this job ?? I've never worked on a boat motor before how hard of a job is it ??? How time consuming for a rookie ?? Would i be better off trying to find someone to do it ?? Thanks Again !!!!
OptsyEagle
With the help from this site you should be able to do it. All the seals come in a kit and you may need a seal puller and few other special tools and definitely a service manual / step by step procedure. As you come to a road block, just start a thread and the experts on this site will help you out. You own a fairly common motor.
I have a CD-18 that I had to re-seal and since my dealer said they wouldn't work on any motor that was built before 1973, I didn't have much choice in who was going to do the job. My suspicion is that the cost of having a dealer do it would most likely be more than what the motor is worth, but others may differ from that opinion.
I would not want to do it again, but I would if I had to. I would just complain a lot as I was doing it. Good luck to you.
lindy46
Seal kit is probably around $20-$25. The problem with this motor is you have to remove the powerhead to disconnect the shift rod and drop the lower unit. You really need a service manual to tackle the job, as there is a carbon seal at the top of the driveshaft with many parts and you have to get it back in the right order. You will also need a new gasket to reinstall the powerhead. Better replace the water pump impeller while you're in there.
onyx
Thanks for the replies and a bit of a pep talk, sounds like it should be FUN !!! Thanks again and I WILL be back with more ???'s after i find a manual. Matt
onyx
What would be the best manual for this ??? Much appreciated !!!!
KYLakebasser
You need to try to find an engine specific manual. The manuals that cover several different years and motors , can be too vague , on specific motors.
onyx
Well I'm having no luck finding a GOOD step by step manual for this motor any suggestions ??? Also what special tools will i be needing ??? So far I see I'll need a seal kit, Powerhead gasket for re install , and a New impeller anything else I should be looking at while it's torn down ???? I just recruited my father in law for help he's a machine builder and says we can do it, I just want to make sure i've got everything before we start !!! Thank you VERY MUCH for any and all replies !!! Matt
OptsyEagle
Well the seals can be a little resistant to coming out so a seal puller would be very useful. Its a metal tool with a small bend at the end with a handle at the other to help you pull them out. A heat gun for the really stubborn ones can also be helpful here. You should also have some sealing compound like 3M #847 to really seal the two halfs all around the spagetti seal and the O'ring on the prop shaft. I also sloshed it into all the screws including the phillips pivot screw.
I also needed to use a 5/16" tap to tap about 3 or 4 threads into the shift rod bushing. I then screwed in a 5/16" bolt and then one can either pull the bolt or what I did was use a 1/4" rod and tapped it out from the underside. There is also a special tool you can get for this, but my method worked fine.
I ended up using a SELOC manual that I picked up at the library. I just photocopied the appropriate pages. It is not the best but with it and some common sense I made it through.
If I were you, I would also get another powerhead seal, OMC#303355 to make sure that is well sealed and if you didn't have it, the powerhead gasket number is OMC #313065 or Sierra 18-2901.
This diagram of the gear case may also be very useful.
You should also know that the impellar in water pump kit #391391 is a little different than the impellar in this diagram or that you may have in yours. I think they upgraded it and I have to say that water pump kit #391391 really works great. You could take a shower from the water that sucker shoots out.
Good luck.
onyx
Thanks Optsey eagle !!!!!! That diagram is alot better than what I've seen so far. Matt
onyx
Can you tell me if the shift rod seal is included in the gear case seal kit ?? or do I need to order this separate ??? Also I'm having no luck finding the water pump kit # 391391 did you order through I boats ?? Thank You. Matt
OptsyEagle
The shift rod seal was just an O'ring which was included in the gear case seal kit. If I recall, I used a Sierra kit and the drive shaft seal it had was not the right one for my motor. I did not know why, perhaps the piece it fit into was changed on my motor. In any event, I just ordered it seperately and went back to work.
I have sent you a private message. Just click "Private Messages" above where the screen welcomes you, to receive it.
onyx
OK , I've started to take apart and on the top of the driveshaft spring there sits a little black cup like washer , and in the manual I have, it shows there is suppose to be an o-ring in the top part of this,but there was not one there and I don't see any in the kit that will fit ????????? Thanks Again in advance !! Matt
OptsyEagle
Well, there is supposed to be one there. I doubt OMC put one in it for cosmetic reasons. It sometimes sticks into that black piece and is not easily noticeable or it could have fallen out and can't be found. If you don't find it, I would suggest contacting your OMC dealer and obtaining another one. The part number is 303347. It would not be included in a lower unit seal kit.
onyx
Well, Optsy Eagle the job is done , gonna let everything cure for a day and fire it up tomorrow. Thank you VERY MUCH once again for all your time and assistance. This is a GREAT forum I've learned more about this first motor of mine than I thought I would ever know boat motors !!!! Matt
onyx
Just got back from the test ride on the Saginaw river and all is well !!! Thanks again SO MUCH to Optsy Eagle and the I boats forum !!! If anyone needs assistance with a lower unit re seal on a cd 17 I'll now be able to contribute.
Look out walleyes come saturday !!!!!!!!!!!!! Matt
coolguy147
was there washers on the screws? i must replace it each time u take the screw out. its a one time deal. make sure u put the rights ones on there too
