Hull tabs, what are they?
Bohunter
What are hull tabs, how do they work and how difficult are they to install? Thanks
Lou_F
Re: Hull tabs, what are they?
Are you refering to these?
http://www.nauticusinc.com/index.htm
I just installed them on my boat, took about 1 hour. Don't know how much it will improve the boat yet, as it is still to cold to venture out. I have however heard real good things about them.
steelespike
Trim tabs both passive and and powered can be very effective. they mount at the bottom of the transom do require holes drilled to mount, with proper procedures, sealer etc.to prevent water intrusion.Both types of tabs can improve hole shot help stay on plane at less power,steady the ride and improve no wake speed wander.You should be sure the boat is trimmed and weight distributed carefully for best performance.Then make the decision about tabs.Tabs will not help a boat that tends to plow or is bow heavy.
