anyone with an older boat with rotting floors found suitable non-wood materials that arent special order??
I'd like to convert over to composite material for the flooring if possible?? I see the composite materials in 2"x4" form at my local hardware store but not in plywood sheet form.
outside of this, the only thing I can think to do would be to put a coat of fiberglass resin and then gelcoat over the boards before installing them in the boat. even then I think they would still start to rot out where the screw holes are unless I caulked over that but I dont think that would look too good.
as for the floor if I went the resin route, I'd get some of that floor grip paint that you use around pools, etc so I wouldnt slip/slide everywhere.
but anyway, anyone have any good alternatives to wood when going through your flooring, etc??
