Re: Can't get full throttle
Yes, the rpm's drop, but the motor doesn't conk out, it runs and pushes the boat, just at a slower speed. As I let off on the throttle (from full throttle), it doesn't change much until I get back to about 1/4 throttle, then it actually gains some rpm's. Through the whole range of throttle, the engine purrs. No misses or uneven firing. The only other thing I can describe is that the tone of the motor changes as I increase the throttle. Hard to describe, but there is a sound that makes me think the air mixture is changing. Butterfly opens fine. Any ideas? Thank you.
