omc 5.7 no power, cant bring boat on plane
Status
Not open for further replies.
rodb267
hey folks, need some input 5.7 omc engine runs fine no load, checked timing, advance timing ok, compression reads 165 to 185 in cylinders, has new carb, fuel pump filters, pulled fule lines in tank check valve fine vent valve clear, engine just wont go above 2600 rpm when under load, carb opens secondaries
open carb growls at you but engine wont increase rpm, feels like boat is overloaded or engine is underpowered like bad rings but no blowby noi oil consumption, pulled valve covers to inspect valve movement all looks fine no indication of worn camshaft, cam timing perfect, no slack in chain, vacume guage reads 18 inches steady at idle , even in gear vacume drops to about 14 inches with steady needle, i was suspecting exhaust restriction but do not get a positive/pressure reading on vacume guage whenhis happens, note vacume guage is run into port on back of intake manifold. ignition system was replaced with breakerless system but i dont know if this could be a problem even whenin drive i took a timing reading and had 18 degrees of advance at 2800 rpm but engine still wont go any faster, i will pull exhaust manifolds and inspect flappers for restriction, any possibilities of bellows collapsing? we did change the prop from 17 pitch to 15 pitch but no change, did notice when trying to diagnose problem if you trim outdrive up seems to make worse rpms seem to drop a few hundred rpms, any suggestions, thank you rodb267.
Gazza1
Re: omc 5.7 no power, cant bring boat on plane
I would say at a guess that you have a fuel supply problem. Check your fuel pump delivery pressure. Also check the float level in the new carb.
a70eliminator
I was just about to mention mechanical advance plate corroded up and stuck but you pretty much covered that. does sound like a flapper off and plugging the exit.
Wonder if the drive could be on the verge of seizing?
Don S
Did it work ok before you changed the ignition system?
rodb267
boat was running this way prior to replacing ignition system.
chiefalen
Ok pull the esa plug and the overstroke switch plug try it then and post result.
a70eliminator
How big is this boat, I hate to even mention watrelogged hull, but it is one unfortunate reality.
chiefalen
He didn't post how big the boat is or what year ether !
Follow both wires back from the shift converter that the micro switch are attached to and the 2 plugs that have the spring clip on pull them part, and leave them dangling, see if it fixs the problem temp. like then we can go from there post the result. Do not pull apart the fuse holders they are in spring clips but larger ones.
Want help do what i ask you to do. You can always plug them back together latter.
rodb267
i just got off the phone with my buddy the boat is a 1989 bayliner 2556 convertible with 550 hours on engine, unfortunately the boat wont be in the water until april 1st so it will be over a month befor i can test it accordingly, hopefully this will be the answer and i will post the results as soon as i can, thank you al l for your imput, i am looking forward to speaking with everyone
soon, thank you rodb267.
chiefalen
This was going on last year? Hah didn't look at where you are.
rodb267
apparantly this problem has been going on for at least 2 years, i became aware of his concern late august in 2008, just as a guy on the dock speaking with my neighbors at a party, he had it to several repair facilities over the past 2 years and spent a lot of money but still no luck, i am one those people that cant sleep until i find the answer. i am excited to get to this boat and disconnect the interrupter and overstroke switches, sounds like the most encouraging news yet. , and about the carb issue, secondaries do open and fuel is flowing, i also poured additional fuel into the carburetor when this problem occurs but still no difference, this is a strange problem and i am sure we will all be happy to find what the final repair will be. thank you rodb267
leeabr
I would love to know what the outcome was here - I have the exact same problem with a 1988 Avanti
Status
