is this the right gasket???
bpmcl00
after taking my riser off to pressure test it i ordered a new gasket from my local boat shop. the OEM part number is 27-860233. But i got a sierra part number 18-0897. when i did a cross reference i did not get the original OEM part number to my sierra part number.
Also my OEM riser looks like a metal flange, this one is like a composite thicker material. Does this matter??
Also whats the difference between restriced flow gaskets and non???
what are there applications??
Thanks guys
Don S
Re: is this the right gasket???
I wouldn't use one on my boat.
bpmcl00
thanks mate.
also should i smooth away any rust or roughness with some sort of sand paper or emory?
and should i use any sealant like Perfect seal or Permatex??
Don S
Re-read the service bulletin I posted above. It covers both of those questions.
Just to ad about gasket surfaces, they must ALWAYS be clean and flat. Otherwise they will not work with or without a gasket.
