Regular wheel bearing grease on the prop shaft
Mas
Re: Regular wheel bearing grease on the prop shaft
Get the OEM "triple guard Grease"...it's waterproof! I guess all grease is waterproof, but TGG is designed not to breakdown as quickly.
MAS
EARLS BOAT
Any Grease Beats No Grease! I Have Used A Marine Grade Grease In My Lower Unit And Have Had No Problems.
mthieme
Use marine grease.
It's cheap - Walmart carries it.
tashasdaddy
agree go to walmart, i also use walmarts super tech outboard motor oil.
ezeke
I prefer the Triple-Guard Grease - I would not use anything else around salt water.
If you buy the 14 Oz. tube for your grease gun it should last you a season or more - part # 0775776.
As long as you remove the prop and grease the shaft once a year, regular wheel bearing grease works just fine. I used it on my sterndrive, which stayed submerged in saltwater all year (Mar-Dec) and never had an issue. If you do not plan to regrease each spring, use the marine grease.
Ladiesinpinknightshirts
Thanks for the good advice. Just came from Walmart. They had everything I needed. I love that place! They and McDonalds seem to be the only ones posting gains these days.
