What to do before i start it up?
wilson750
I got a 88 Mercury 115 HP over the winter, It was sitting for 2-3 years!!
It turns over with a little gas, but what would you suggest i do before i try to make her run for awhile?
New plugs? Any kind of carb cleaner i can spray in her?
I was going to do the lower unit oil once i know she runs good!!
Any help would be great!!
Laddies
Banned
Re: What to do before i start it up?
Change the gear lube, then new fuel now remove item #11 and clean the high speed jets with some spray carb cleaner before replacing the #11 plugs (link) http://www.mercruiserparts.com/Show...N/15183.png&inbr=359&bnbr=70&bdesc=Carburetor now pump the primer bulb to see if each carb is getting fuel. Now reinstall the drain plugs and prelube the cyls. With it hooked to a hose see if it will start. If it sounds OK I would install a new impeller and head for the lake.
wilson750
What should i prelube the cyls with? WD40?
When i take the #11 plugs i should leave them out and pump some gas into them?
Thanks for the fast reply, its getting warm here in pa, So i need to get to work!!
wilson750
Ohh One more thing.. How do you go about removeing the bottom plug? Its soo tight to the fairing!! Any tips on that?
Laddies
Banned
Some models they are about impossable to get out, so all you can do it try. Yes, WD 40 or most any spray lube similar will work.
wilson750
Ok thanks.. One last thing, When i take out the #11 plugs on the carb! Should i pump gas into them while they are out?
Thanks for all your help Laddies
