FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Ok guys I need your help again
On the port side of the head there is a gasket that goes under the cover?
does anyone know what the part number is and what to ask for?
It is leaking when I start it up aroung the top plug.
thanks pappy3
The cylinder head gasket is #318358, but it does not have anything to do with the spark plugs. Is it the water cover that is leaking or the spark plug? The water cover gasket is part number 318335.
If you go to the BRP/Evinrude site, you can click the parts diagram in the upper right corner and navigate to the parts catalog for your motor. The engine gaskets are shown on the "Cylinder and Crankcase" diagram.
thanks guys incase I didn't make myself clear it is the cover on the head that has a hole where the spark plug comes out, it isn't leaking in the plug I can see gasket material where it is leaking. THANKS AGAIN
i use a little non harden just enough to hold it on. and get it tight, they are 1/4 inch bolts into aluminum, so you want the tight, but not reamed out, or broken.
