Coil/felt pad
noah4009
I have a 1971 55HP chrysler. As you can read my other threads, I am dead. I just removed the flywheel and noticed one of the pads next to coil, that rub on cam is not touching, not even close. Could this cause an engine not to start?
Frank Acampora
Re: Coil/felt pad
The felt pad is a wick that should be saturated with a drop or two of oil. Its purpose is to lubricate the cam so that the rubbing blocks of the point sets do not wear. There should be one felt pad on each set of points. they usually take a "set" and only touch the cam at the high point. Do not use too much oil! It will come off the felt and foul the points either causing burned contacts or insulating them.
The felt pad not touching should have nothing to do with starting problems other than excess oil getting into the points.
Bard1
Re: Coil/felt pad
Yep Frank is right. I just learned all that from all the vary knowledgeable guys on this sight. change the pad ,but it has nothing to do with starting. Check spark,compression, condensers, points ,coils.
noah4009
Re: Coil/felt pad
Yea these guys are on the top of there game. But according to Frank it does. To much oil and it can foul points. Thanks, but you say check this, that, this, that, and this. How?
Bard1
Re: Coil/felt pad
Click on my old thread "Stuck on land" . You will find everything on how to check spark,coils all of it.
