confused about direction of lower seal of A1 sterndrive
sarantis
The manual (page 3A-29) says to install the lower oil seal of drive shaft housing with lips facing up (toward top of housing) whereas at the relevant picture the sterndrive is up side down.So, the lips of the lower seal face the real top or the real bottom of the housing? And something else,do you feel the gap beteween two seals with grease?
chiefalen
Re: confused about direction of lower seal of A1 sterndrive
These are the seals with the springs in them. The spring sides face away from each other.
sarantis
I think i find out why the compression test couldn't find the leaking!About the gap between the two seals?Do you feel it with grease?
Thanks a lot
sarantis
Excuse me again ,so when you see the spring the lip is from the oposite side?
sarantis
now i think i understand chiefalen.when you say the spring sides face each other you mean the springs can't see each other.Right? And about the gap between the two seals?Do you feel it with grease?
chiefalen
The springs do not see each other.
sarantis
Chiefalen
Not that i don't respect your experience but
a)i just came back from the car mechanic who told me that the liquidproofness of the seal is from the side of the spring so the two springs shouldn't see each other
b)what you say contradicts with the service manual unless the lip of the seal is the oposite of the spring's side something that doesn't look normal
PLEASE HELP I'm more confused now!
chiefalen
The flat part of the seal is up against the flat part of the other seal and no grease between them they wore out. Thats why you have to replace them.
No grease on the shaft where the seals touchs the shaft dry shaft. No grease.
Dip the seal in oil or rub oil on the inside of the seal.
sarantis
Now it's clear.I'm sorry ,at your first reply i ignored the word "away".
Thank you very much.
