Bolts for trailer bunks
kabcpapc
The original bolts in my trailer bunks that mounted the bunks to the trailer were carriage bolts. I have seen another style of bolt on some website that has a head that looks like a tee nut (it has prongs that punch into the wood to keep the nut from turning) but I can't remember what website. Can anybody tell me what the name of the bolt is and where to find it?
tashasdaddy
Re: Bolts for trailer bunks
i just use hex heads, makes it simple
Seon
I used 3/8" galvanized carriage bolts.
gstanton
You are correct that they are called Tee nuts. They are usually used in furniture, stools, and bi-fold doors. I've never seen ones big enough (1/2 - 3/4) to do the job you're looking at. Nor have I seen galvanized or stainless - but - none of that means they don't exist.
Galvanized carriage bolts are right for the job.
kabcpapc
The bolts I have seen have the head that looks like the tee nut. On the website I looked at, I thought I saw some that were 2 1/2" long. My mind may be playing tricks on me again. I wish I could find that website again. I'll keep trying.
Fastenal has the carriage bolts in stainless and galvanized. What are the pros and cons of the stainless versus galvanized?
sturdavj
I too have seen larger size bolts. Sorry I can?t remember the application, maybe auotmotive.
Seems to me the ones I am thinking about were black iron, not coated or stainless.
Good luck with your search.
My local Lowe's carries ss tee nuts, as well as carriage bolts, and lag screws. I think they had the tee nuts up to 3/8". If you use the tee nuts take your time to get the location right the first time becuase that is all you got until the hole is too big and the nut just spins.
KLINDWW
Price! A good stainless bolt will run you 5 times the cost of galvanized. Also remember that all stainless is not created alike. You will want 316 stainless or an equivalent.
luv2b0at
The type of bolt I think your writing about is called a timber bolt. Please see link below. THe spikes comong off the bottom side of the head are not very long. Just ednough to cause some friction and keep it from spinning as you install the nut on the other end.
http://www.portlandbolt.com/products/bolts/timberbolts.html
or another version
Hobbes_24
I work for a fastener company (similar to Fastenal they are our competition) the largest tee nut that is available i know of without being infront of our system is 3/8-16 in stainless,
http://www.mcmaster.com/#90973a120/=hxkz9
and 1/2-13 in steel
http://www.mcmaster.com/#90975a033/=hxkui
Im sure i can check one of my other suppliers but i wont be able to until i get to work monday. McMaster Carr is an online supplier we use as a last resort supplier if we cant find our product anywhere else. They are very expensive and you have to pay for shipping on top of the price.
hope this helps, I'm new to the boat building forums but i have a bit of experience with fasteners. lol.
Hobbes_24
I have had alot of people ask what to use for drywall at work. and every time i tell them this product
http://www.toggler.com/products_hwh.html
but they never listen to me and they buy the little plastic screw in plugs instead.
Here is how they are installed. (link is from same page as last link)
http://www.toggler.com/products_hwh_installation.html
The weight ratings on these are insane. I have not personally tested them myself (My workshop is all block walls and pegboard) But if i ever need to replace anything in my house this is what i WILL buy.
-Chris
*EDIT*
sorry . to answer your question.. The Tee nuts may work in drywall but i don't know how much weight they will support. i suppose for a light application they would work fine. But the Toggler bolts were tested successful for a 250 pound load on 1/2 inch thick drywall and failed at over 350 pounds.
cbavier
Thanks Chris. I bookmarked both pages for future reference. I've used the Butterfly/ wings but wondered if there wasn't something better. We are in a new house 8 years ago and hanging heavy stuff into drywall can be a challenge.
Baylinercapri1987
Galvanized carriage bolts, and countersink them into the wood, 5200 over the holes. That's how I just did it
luv2b0at
It looks like no one is reading kabcpapc's initial question. He is not lookinf for t-nuts. He is looking for,
"I have seen another style of bolt on some website that has a head that looks like a tee nut (it has prongs that punch into the wood to keep the nut from turning)."
Hobbes_24
http://www.mcmaster.com/#carriage-bolts/=i1glh
give it a second to load and it is the first option.
sorry to get off topic man..
I think there may be a cheaper soloution than this site. for (the smallest one) 5/8-11 x8 inch screw its $3.38/each....
but at least you can print off a pic to show your local suppliers.
-Chris
kabcpapc
Can't use the timber screws (bolts). Minimum length is 8". The original carriage bolts were 2". I went to the local Fastenal place. They can special order the bolt I want in 2" but I have to order 100. I don't think I need 100!!!
luv2b0at
Here is one method I have had to use in the past. I had to install some carriage bolts that had the head counter sunk and they would just spin no matter how much you turned the nut. It sounds a little odd at first, but it worked. It requires a bolt that is a bit longer than origianl, but you can cut the excess off after you are done if you need to.
Install the carriage bolt. Start on the nut you will use to hold the bolt in place. Install two additional nuts and use them as jam nuts to each other. Once they are jammed, hold the upper nut with one wrench while tightening the very first nut. Sometimes as the bolt is tightened, it will hold itslef and you can let go of the jam nuts. If not, the very first nut is tight, you can unjam the other two nuts and remove them. The threads remain in good condition and the nut and bolt can be removed in the future if need be.
If my attempt to explain this leaves you confused, let me know and I will try to make up some pics.
Wee Hooker
Install the carrage bolt with some 3m 4200 marine selant (or 5 min epoxy if your in a real hurry.) It won't turn.
reelfishin
They are referred to as torque head bolts or timber bolts, I've seen various renditions of the same idea, some have actual spikes or points while others are just crimped slightly to form a spline or four sharp edges.
We used to use these in the building of boardwalks, docks and other marine wood projects to speed production. They came in all sizes, we had them up to at least 3/4" in diameter, all were galvanized.
There was one other style bolt we used, which had diagonal holes drilled across its head in three directions in which a spike or large nail was driven to secure the bolt and prevent turning or it dropping into the water during assembly. I don't recall where they came from, but they were real life savers when working over water.
I think what your looking for is something along these lines, although their probably not necessary, they do make removal a bit easier but a rusted, frozen bolt will still spin in the wood no matter how well it's anchored.
http://bacoenterprises.thomasnet.co...ipped-galvanized-for-dock-and-marine-builders
http://seaportmarine-e.com/catalog/index.php?cName=bolts-timber-bolts
http://www.follansbeedocks.com/Boat-Dock-Catalog/Boat-Dock-Fasteners-New.html
http://www.portlandbolt.com/products/bolts/timberbolts.html?gclid=CK_J8q-i45gCFQEoGgodXmajdw
http://www.vafasteners.com/timber_bolts.htm
