Direction of Impeller
steven2reel
Please someone how to put in the impeller in the impeller housing. Do I bend in clockwise or counter clock wise, look into the opening of the housing?:confused:
Joe Reeves
Re: Direction of Impeller
Holding the housing upside down in your right hand, the impeller would be inserted in a counter clockwise direction.
However, it really doesn't matter as the rotation of the engine would immediately correct the blade direction as soon as the engine cranked over.
tx1961whaler
The motor turns clockwise. When putting it back together, try rotating the drive shaft by hand and it will be obvious which way the ears go. Don't worry, even if you get it backwards, it will reverse itself, but it's nice to get it right the first time.
F_R
The above comments assume you are installing an impeller that has long vanes sticking straight out. Not all of them do, so not all are self-correcting. Nevertheless, the vanes trail back when the shaft rotates. Think about it--it wouldn't make sense to have them pointing forward. They would "stub their toe".
