Re: OMC Ford 302 Prestolite ignition weak spark
The oem coil was not an internally resisted and I replaced it with a internal resisted one.
Soooooo, just to understand this, you replaced the OEM coil that didn't have an internal resistor built in, there is no external resistor or resistor wire, these resistors were all installed to prevent points from burning up really fast, and your distributor doesn't have points to begin with because it's an electronic ignition. Am I right so far?
So you now have weak spark since you replaced the OEM coil (without an internal resistor) with what you though should be there (one with an internal resistor), is that correct?
Personally, I have never installed a coil on a boat that I thought it should have, I usually just get the right part as suggested by the manufacturer. I really have no idea if it's an internally resisted coil or not. But they worked.
I do know that many years ago a customer replaced his points distributor on a Volvo with a new BID distributor like you have, but failed to remove the external resistor. It was hard starting, and didn't run well, (missed a lot). Once the external resistor was removed, it started and ran fine.
