Speakrdude
Ensign
Thread starter- Joined
- Feb 25, 2004
- 942
On my 94 Johnson Fastrike 150, my #3carb. has fuel "pouring" out of its overflow hole on the bowl. I have dissasembled and reassembled 3 times today hoping I would see something I may have over looked. The needle valve seems to be fine, I checked the float for boyancy and or leaks, all seems fine. I even tested the fuel inlet with a hose with the needle valve opened and closed to make sure the valve was operating. But, when I fire her up, fuel pours out of that hole.
Any ideasbefore I order all 6 carb kits and rebuild? Is there a fuel pressure regultor I should look into?
Thanks,
Jim
Thanks,
Jim
