Fuel Tank Size
krakatoa
Hello Guys
Just need to know If anyone of you have any idea of the size for the fuel tank on a Glastron SSV190 from 1993. Its the below deck 35 gal Original One.
Thanks!
tashasdaddy
Re: Fuel Tank Size
i would say contact glastron and ask.
krakatoa
Re: Fuel Tank Size
Yeap, thats the right choice, the problem is that those guys drop in the recycle bin all info of any boat or model after 5 years :( . Anyway I will drop a call to Genmar. The Hardway is to uninstall a lot of parts including the seats and carpet to meisure by myself :(.
Re: Fuel Tank Size
Ayuh,...
I'd think that running it Down,+ then refilling it would give you a Close Enough Idea of what it'll hold...
Re: Fuel Tank Size
It is probably a standard tank. If you can determine if it is aluminum or plastic, you should be able to get an idea by looking at the 35 Gal models by Tempo and Moeller. They list dimentions for their models.
krakatoa
Re: Fuel Tank Size
Chris, the fuel tank is Plastic and can hold up to 35 gallons, I already took a look @ Mollers tanks but I went confused cause they also have a few models for this capacity with the Hull shape and other just like a square shape.
Willyclay
Re: Fuel Tank Size
My experience with built-in tanks is there is usually one or more removeable plates/hatches in the floor providing access to the hose connections, sending unit, etc. The tank manufacturer's name on an ID plate/tag should also be in that area. If so, you can directly to the source. Good luck!
rebars1
Re: Fuel Tank Size
You might be able to slip a tape measure in the access hole(s) to get the dimensions. Some below deck tanks are "V" shaped on the bottom.
Are you wanting to replace it?
krakatoa
Re: Fuel Tank Size
Yeap, ur right
Re: Fuel Tank Size
Ayuh,...
It's a Plastic Tank,..?? And you want to Replace it,..??
Is it Leaking,..??
krakatoa
Re: Fuel Tank Size
No my friends, its not leaking. But the problem is that he likes to chunk the gas over the fuel sender, there is no matter If I change the gasket, there is anyway to avoid this???
Zfloat
Re: Fuel Tank Size
Looking to determine the size of my fuel tank for my 2000 Caravelle 181 Center Console. Just bought from estate and have no specs or info other than what I can look up.
Any help is appreciated.
Zfloat@comcast.net
Re: Fuel Tank Size
Hey Z, Bring a portable tank with you and run the main tank dry, switch to the portable tank and then fill the main tank. On an 18 footer, expect 30-40 Gal tank, as standard.
Zfloat
Re: Fuel Tank Size
Thanks for the helpful advice Chris, I'll give it a try!
Zfloat
Re: Fuel Tank Size
Huh,..??..??..??
Zfloat,... If you ever expect to use that email address, I'd suggest you edit it out of your post,+ Never post it again...
If a webbot finds it, it'll be Spammed into Oblivion...
