mercury 70hp oil leak
csootsman
Hello, I am new to the forums. A friend directed me here.
My question is I have a 87 I believe, 70hp mercury outboard. I just recently purchased it used. The motor runs great, however the other day I noticed that when I had the motor trimmed in the trailering position I noticed a small amount of what I believe to be gear oil seeping out of the water intake holes.
I have drained the gear oil and it was milky and I also noticed that I was missing a seal in the gearcase drain plug. I will be replacing the seals on the drain and vent plug, however the oil leaking from the water intake concerns me. What gasket and or seal would I most likely need to replace.
Thank you for your time
Clair Sootsman
tashasdaddy
Re: mercury 70hp oil leak
the oil may be normal. http://forums.iboats.com/showthread.php?t=207285. you are on the right track to renew the plug seal, and refill, then check it after a couple of runs. those seals are the #1 place for water intrusion. if you have water next time, you need to pressure check the lower, and find where it is leaking.
csootsman
Ok, I replaced the drain plug gaskets. But I am still getting a small amount of water from somewhere. I just ordered a service manuel for this outboard. I am thinking that I need to replace some seals?. Also the gearcase looks fine , no cracks. I also pulled the prop and found no fishing line.
I am pretty handy with a wrench, does this sound like something I could do. Also before I start doe I need any special tools? Thanks
ps the ser#0B274515
If gear oil is leaking from the water intakes, it is likely the waterpump base gasket, seals or oring is leaking. it is a fairly simple fix. You drop the lower unit, remove the cover of the water pump, remove the impeller, pry up the waterpump base and install a new base which has the new driveshaft seal installed in it, with a new gasket and oring. Now install a new stainless wearplate and it's two gaskets and a new impeller. Reeassemble the waterpump and reinstall the lower unit.
when you manual arrives, read the procedure, buy the parts and have at it.
csootsman
Thank you Chris, Now if I can go to the well one more time. Any suggestions to where I could get these parts online.
Clair
Clair, Those parts are pretty common. Sierra, Merc and probably GLM make them. Try this site, try ebasicpower.com, try West Marine and Boaters World
A local Merc dealer is a good place since the cost will be pretty close to mailorder, but you will get the correct parts. Sometimes ordering the waterpump base is a challenge. You should inspect the upper waterpump housing for cracks and wear. Replace it is necessary.
