Re: '92 70hp is still getting hot.
Here's an update:
I pulled the head off and found water! Cylinders appear to be fine, I oiled them up some. The gasket looks good. This is probably due to a bolt that I had a problem with not getting tight. I installed one just abit longer and perhaps it bottomed out. It seemed to get tight with the torque wrench. When I ran it, I had water leaking out of this bolt and the one across from it. This was all last week.
Today I also pulled the exhaust cover off and made sure that all the water passages were clear. I reamed them out with a drill bit by hand then blew them out with air, everything looks good. Exhaust cover is back on and tomorrow I hope to get a new head gasket.
This overheat problem may have been resolved a week ago but the bolt thing has thrown a wrench into the mix. Tomorrow, after work, is another day.
Wayne
Here's an update:
Wayne
