asdasc
- Aug 28, 2008
- 680
I have an old Evinrude controller that once was used with a 59 18hp motor I got. Today I decided to take a look at it to see if it was frozen. At first I thought it was, but found that it was just REALLY stiff. I got the bright idea that I would pull the cable all the way out and spray penatrant thru it and put it back together. Well, after about 2' out I chickened out and tried pushing it back in. NO LUCK!
So tell me, have any of you done this before? Is it possible?
Will things go better once I fully commit and flush the cable good with WD40 or something?
By the way, the controller seems fine and just needs some good cleaning and lube. The cable is where all the friction is.
