cprince
Thread starter- Joined
- May 22, 2008
- 148
I have another one of my brilliant ideas. I want to make a battery bay under the center bench on my little 14foot tinny. I want to keep weight down to a minimum, so to that end, the batteries will be easy in and easy out. This will be a 12 volt setup only. I only have 6 connections listed, but I will likely go with a few extra for any future needs.
There are two things that I am looking for suggestions with; Where to get the clips that I have in my head (and in my diagram) that will accommodate the battery posts. The other thing is the power block; what I have crudely craw; does it exist? What is it called? Can they accommodate recommended gauge wire? (I am assuming 16 would be good?)
Is the amperage the same at the first post as it would be at the last post? Should I use fuses or breakers?
Thanks in advanced!
Thanks in advanced!
